Sharkcad / Viacad 14 vs MAC OS 10.15
Thanks: 16 times Was thanked: 7 time(s) in 4 post(s)
Hello Any feedback about Sharkcad / Viacad 14 on MAC OS 10.15? Is there any problem for general use like the 10.14 or it's working almost normally? Any feedback is welcome! Br, Nicolas
1 user thanked Ovocom for this useful post.
Thanks: 5 times Was thanked: 3 time(s) in 2 post(s)
Same question... I'm currently on Sonoma 14.7, but considering upgrading to Sequoia 15.1. Wondering if ViaCAD 14 runs OK first. Also, I'm on ViaCAD 14 build 1623, and it says (if I check via the interface) that I'm running the latest version, but that clearly isn't the case. What is the proper upgrade mechanism? Thanks, -Steve
Hi. I asked PunchCad team. They confirmed that v14 is OK with Sequoia.
Now, I'm running Sharkcad 14.1.0 (1654) on Mac OS 15.1, and it's fine. No new problem, only the same bugs as before (but I can work normally).
To download the last version, go here:
http://masterviacad.com/beta/beta.php
Originally Posted by: Ovocom Hi. I asked PunchCad team. They confirmed that v14 is OK with Sequoia.
http://masterviacad.com/beta/beta.php Perfect - Thank you !
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
I there any other new build for V14 than 1654? Thanks Luis G
Thanks: 49 times Was thanked: 88 time(s) in 59 post(s)
Hi Luis, As far as I know build 1654 was the latest, and that's what I am running in Sequoia. Mike
