#1 Posted : Tuesday, August 20, 2024 3:15:28 PM(UTC)
Got this issue,
trying to print or save to pdf a model to sheet drawings is not working, screen shows drawing correctly, but the printing doesn't render objects lines but dimensions
Attached the screenshots of the screen display drawing and the pdf results where no lines objects are displayed
Any one with this issue and how to fix it?
In V15 beta is working ok
Sharkcad pro V14.1.0 (build 1654)
MacOS Ventura 13.6.4
powerbook i9, 16 Ram, AMD Radeon Pro 5500M 4 GB
Edited by user Tuesday, August 20, 2024 5:00:29 PM(UTC)  | Reason: Not specified
ScreenOf Drawing.jpg (137kb) downloaded 4 time(s).
MacOSX Sequoia 15.7.7
#2 Posted : Thursday, August 22, 2024 5:14:25 PM(UTC)
Issue is on 1654 build, I installed oldest build 1645 and now works
thanks 1 user thanked lgrijalva for this useful post.
GARLIC on 8/22/2024(UTC)
Claus2
#3 Posted : Friday, August 23, 2024 12:16:17 AM(UTC)
Claus2
Was thanked: 29 time(s) in 16 post(s)
As a workaround flatten the views before printing. Then undo the flattening.
#4 Posted : Tuesday, August 27, 2024 8:48:12 AM(UTC)
Thanks for your tip, but Already tried, and in 1654 build flattening views erase all dimensions,
#5 Posted : Tuesday, August 27, 2024 1:18:39 PM(UTC)
The printing pdf situation has always been shambolic. If the views are rendered in colour and the border of the view overlaps anything it blanks that object out.
Sometimes the view type, not sure how it works on the latest version, but I seem to remember in the pro version you can use precision curves, which gave worse results than the other option.
The only other options to check are in the print set up. I remember you have to do the print options first and get the layout correct and there may be some radio buttons in the to select what to print?
Certain pdf print programs don't work either, I ended up using cutepdf in version 12.
thanks 3 users thanked UGMENTALCASE for this useful post.
damhave on 8/27/2024(UTC), GARLIC on 8/27/2024(UTC), jlm on 8/28/2024(UTC)
