Keith2019
#1 Posted : Wednesday, June 26, 2024 6:13:25 AM(UTC)
Keith2019
I hope this makes sense.
I was wondering if there is away to section a 3D Solid model while working on it, without having to first create a Model to Sheet, then Section a 2D view it in the Sheet?
Thank you,
Keith
rockyroad_us
#2 Posted : Wednesday, June 26, 2024 10:52:55 AM(UTC)
rockyroad_us
You can use the Cut Section command. Just draw a plane in the direction you want cut, use the command on the solid, and then you'll get a 2D profile. Just put it on a separate layer. Hope that helps.
thanks 3 users thanked rockyroad_us for this useful post.
Keith2019 on 6/26/2024(UTC), damhave on 6/27/2024(UTC), MPSchmied on 6/27/2024(UTC)
Keith2019
#3 Posted : Wednesday, June 26, 2024 6:02:49 PM(UTC)
Keith2019
Hello Rockyroad_us,
Thank you very much, it worked a treat :-))
Kind regards,
Keith
