Solid Modeling
Is there a faster way to split a solid???
I came from a cad system where I could use the workplane to cut a split a solid. I see that's not an option in VCPro14.
So what I am doing is positioning the workplane where I want to split the solid, see pic. Then I am drawing 2 lines, 1 on X and 1 on Y. (Lines in green). Then I am adding an infinite plane by 3 points (plane in red). I use the infinite plane to split the solid!!!
Is there any way I can speed that up, with fewer mouse picks, fewer lines (or no lines). Your ideas please!!!
Mike...
P.S. The best solution would be for Tim Olson to add Split by Workplane as an option... ;-)
Edited by user Wednesday, November 8, 2023 5:53:19 AM(UTC)
(56kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 14 times Was thanked: 22 time(s) in 14 post(s)
Splitting a solid is very easy in Shark.
Simply set an infinite plane where you want it in x y or z on your solid and then use the split solid tool.
Edited by user Monday, April 1, 2024 6:37:01 AM(UTC)
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
It's very easy to split solids with surfaces. You can easily extrude a line or curve with the extrude surface tool. Then use the split solid tool using the surface you created. You can also trim a solid with a simple line or curve perpendicular to your view with the trim solid tool, but it trims off one end of solid and does not keep the other end of the solid.
I use both of these tools so much that I put them on a custom tool pallete so I don't have to hunt these tools down.
creativecad attached the following image(s):
(167kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
ViaCad 10 Pro ViaCad 9 Windows 10
4 users thanked creativecad for this useful post.
Thanks: 38 times Was thanked: 63 time(s) in 45 post(s)
Originally Posted by: creativecad You can easily extrude a line or curve with the extrude surface tool. .
Damn, that's a much easier way, I really need to read up on the Tool functions. :)
Thanks for the that
Mike
Solid Modeling
