Jean-Francois Jacques
#1 Posted : Tuesday, February 6, 2024 11:14:29 AM(UTC)
Canada
1- Make a cube
2- Be sure that your track ball window is open
3- Select the cube and go to the gripper window
4- Change attach mode (user positioned)
5- Drag the mouse (without click) over the track ball
6- Your model will move around without any click
7- I f you choose size of the gripper your model will be stick on your mouse without any click !!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
thanks 3 users thanked Jean-Francois Jacques for this useful post.
GARLIC on 2/6/2024(UTC), damhave on 2/6/2024(UTC), jlm on 2/10/2024(UTC)
CADCAM
#2 Posted : Sunday, February 25, 2024 8:40:18 PM(UTC)
CADCAM
Was thanked: 22 time(s) in 14 post(s)
Originally Posted by: Jean-Francois Jacques Go to Quoted Post
1- Make a cube
Yeah gripper is broken in 1649. I've gone back to 1645.
#3 Posted : Monday, February 26, 2024 2:53:48 PM(UTC)
I got this to repeat today! Checking into a fix...
#4 Posted : Monday, February 26, 2024 9:28:48 PM(UTC)
I sent a build out to JF tonight to see if the issue is now corrected. If he confirms the correction, we will roll out a new WIP to everyone.
It actually impacts more than just the gripper, but very noticeable with the combination of steps JF noted.
Edited by user Monday, February 26, 2024 9:30:06 PM(UTC)  | Reason: Not specified
thanks 3 users thanked Tim Olson for this useful post.
CADCAM on 2/27/2024(UTC), damhave on 2/27/2024(UTC), jlm on 2/27/2024(UTC)
#5 Posted : Tuesday, February 27, 2024 10:33:24 AM(UTC)
Canada
Thanks Tim,
First - From rapid test the Gripper looks to work normally ...But Reset Axis have no effect !!
Second - I don't like to see the shape of my Iso Line (attached pictures) (build 1650 and was in previous build)
Third - I did a 3D printing and for the first time my 3D print have a lot of facets and the print failed !!
IsoLine andvariable Blend.png (512kb) downloaded 6 time(s).
Jean-Francois Jacques attached the following image(s):
3D print.jpg (300kb) downloaded 1 time(s).
thanks 2 users thanked Jean-Francois Jacques for this useful post.
GARLIC on 2/27/2024(UTC), damhave on 2/27/2024(UTC)
#6 Posted : Tuesday, February 27, 2024 11:06:44 AM(UTC)
Excellent.
Reset Axis only resets the axis. It does not change the origin.
I don't recall making changes to iso lines for any of the v14 builds.
Same for this item, I don't recall changes to faceting for any of the v14 builds.
IsoLine and facet creation are handled by ACIS which has been the same version for v14. Might be something related to the part.
The 1650 from 1649 build changes were limited to a fixing a mouse button down value getting stuck, and some pen color/material changes per face and body.
Thanks so much for quickly testing! I'm going to start preparing a 1651 by running some regression tests tonight.
#7 Posted : Tuesday, February 27, 2024 2:13:16 PM(UTC)
Canada
Perfect Tim !
But tell me, is it normal to have this iso line shape ?? It isn't Kosher !!
Screenshot 2024-02-27 at 10.58.39.jpg (128kb) downloaded 1 time(s).
#8 Posted : Tuesday, February 27, 2024 3:58:36 PM(UTC)
Oh! It's a facetted silhouette edge.
It's somewhat expensive to calculate a precise NURB silhouette. So I calculate a facetted poly line for view changes.
But I thought it should discard a silhouette associated with a different view orientation.
Will check...
ALBANO
#9 Posted : Wednesday, February 28, 2024 6:02:28 AM(UTC)
ALBANO
Was thanked: 28 time(s) in 15 post(s)
How shall I use the gripper like in the attached screenshot?
Please, please, please make the gripper stay the same size, regardless of zoom, like in ALL other CAD-Software on this planet.
ALBANO attached the following image(s):
Bildschirmfoto 2024-02-28 um 12.59.39.png (305kb) downloaded 2 time(s).
#10 Posted : Wednesday, February 28, 2024 10:54:36 AM(UTC)
Canada
Will check...
Thanks Tim, I understood, this irregular iso line isn't an anomalie... perfect!
Last week I had a problem with the Push / Pull Tool. This morning I cannot to reproduce! Bizarre,(not a matter) the Distance Statut Window doesn't accept the 0 value !!
Guest (5)
