Thanks: 49 times Was thanked: 86 time(s) in 58 post(s)
Hi, macOS question Anyone having issues with trying to click, holding down and dragging on there toolbar... aka SharkCAD defaults to two point circle and trying to select single point circle from the toolbar icon? Mouse or trackpad behaviour is as expected if you drag the tool options off the tool strip... seem to remember having this issue before, and I was definitely having it with build 1645 & now 1649. Yes macOS Sonoma has had incremental updates, but my external monitor setup hasn't changed, or my Apple System Settings by me. Not the end of the world, just frustrating Mike
.... definitely related to the external display again, as fine on native MacBook screen with USB-C display disconnected
Originally Posted by: CADCAM Tim did you see my post about the gripper Yeah, what was it? Mines broken in 1649. User position and at selected doesn't work :-(
I told the same thing to Tim about the gripper with no answer...
https://forum.punchcad.c...ts&t=11051#post42489 METEORE DESIGN / KEKO Stand Jean-Francois Jacques, Industrial Designer SharkCad Pro V14 B1653 Platform macOS 14 Sonoma
1 user thanked Jean-Francois Jacques for this useful post.
... I think my issue is possibly related to a macOS incremental update a few weeks back, as I've just downgraded to build 1641, and the click and drag function for selecting other types of drawing tools is still not working, unless you tear off the tools from the Tools window... grrrr Mike PS Checked my System settings against previous instances & posts, and nothing has changed my end.
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
Thought that perhaps I might let Tim know that WIP 1641 is working mostly very good for me lately. I tried this WIP 1649, and it is about terrible. I don't have time lately to do much testing. It seemed that inspector was not changing the properties of lines and circles, the gripper was offsetting itself when I used it, and when I tried to click on parts to drag them to a new place I could not drag them. I have mostly just been doing 2d work with lines, rectangles, circles, and dimensions. I do just a little solid modeling. Anyways, 1641 is handling these things pretty well so I'm sticking with it for now. I'm using windows 10 pro. Sam
ViaCad 10 Pro ViaCad 9 Windows 10
1 user thanked creativecad for this useful post.
>>it seemed that inspector was not changing the properties of lines and circles,
I made some changes tonight where the inspector was not always updating.
And in the process corrected extraneous flashing of the controls.
FYI: thanks Sam for your bug reports. They are awesome in detail and really help me in fixing bugs.
Edited by user Saturday, March 2, 2024 10:35:52 PM(UTC)
2 users thanked Tim Olson for this useful post.
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
Just installed 1649 WIP Shark Pro PC. Huge problem for me, can't select an axis to ROTATE, only Z available. Click on X, only Z remains. Going back to previous version. Please fix. Thanks, Larry
Was with Build 1649
My files have suddenly the same name ?? I lost one of them !!
Jean-Francois Jacques attached the following image(s):
(127kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
