Import/Export
Exporting multi text to DXF, CGM etc. (#4492)
Is there a way to smash or explode multi line text prior to 2D export? I've tried to change the entity type to lines, curves and polylines. I'm using v8, and it also chrashes during export. Mike
Hi Mike You can try use the single line text with \P to separate lines. What plane is the text on before export? Regards Jason
Mike Would it be possible for you send me the file that is crashing when you export to dxf? Tim
Import/Export
