scruff007
#1 Posted : Friday, January 26, 2024 5:44:04 PM(UTC)
scruff007
Was thanked: 14 time(s) in 4 post(s)
why cant viacad or sharkdad constrain two small arcs ... yes they will do two semi circles but nothing smaller watch first 2 minutes of this youtube to see how they can do it in a program called onshape but i cant do same with via cad programs https://www.youtube.com/...v=Hnu3ib9AaQs&t=134s you would think should be able to constrain any shapes/lines ??
thanking you
scruff007
scruff007 attached the following image(s):
viacad constrain pic.png (151kb) downloaded 7 time(s).
#2 Posted : Sunday, January 28, 2024 4:32:29 PM(UTC)
You can add a concentric constraint to an arc or circle. See video link below:
http://www.csi-concepts.com/Demo/videos/v14/concentricConstraint.mp4
The concentric constraint requires a curve with a radius and center point so it will only work with an arc or circle.
If you have an arc and circle that won't concentric constrain, please provide the file such that I can look at in the debugger.
Edited by user Sunday, January 28, 2024 6:20:00 PM(UTC)  | Reason: Not specified
MaiFy on 1/31/2024(UTC)
Keith2019
#3 Posted : Sunday, January 28, 2024 9:40:19 PM(UTC)
Keith2019
Hello Tim, a great demonstration video. Thank you for supplying it. Kind regards, Keith
scruff007
#4 Posted : Monday, January 29, 2024 9:57:04 PM(UTC)
scruff007
hi have attached pic to my original post showing the two arcs i want make concentric by using the constrain tools hope this hepls
#5 Posted : Tuesday, January 30, 2024 7:36:06 AM(UTC)
Are you using a conic? You cannot do a concentric constraint with a conic.
It must be an arc or circle using a radius and center point definition.
scruff007 on 1/30/2024(UTC)
scruff007
#6 Posted : Tuesday, January 30, 2024 10:40:11 PM(UTC)
scruff007
hi tim
yes my mistake iwas using conic and understand it now ....this is great program
thanks
