Hello,
I have a problem with a file I saved in ViaCAD 9.0 at the last session.
When I try to open it, there appeares a message, the file is damaged.
"This file is damaged! Cannot read into application.
File position: 1632251
File size: 1632251
Filename: xyz.vc3"
Is there a chance to rescue the file?
I opened the file in a texteditor. At the end there is the Word "SUCCESS".
Could anybody help me? It took a few hours to create the file.
matze134 attached the following image(s):
(8kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 28 times Was thanked: 7 time(s) in 4 post(s)
Sorry for the negative message, but this is an issue with SharkCAD also. File is probably lost. A tip is to regularly do incremental save a copy under new name on any file you work on as well as have the backup feature turned on. E.g. add date and version to your filename like "filename 240112-1..." and so on. A "benefit" with this software is that you thus end up with GB of data for files. For you own safety also save a few of the various file versions to your backup..
