2 Pages12>
epicycloid
#1 Posted : Tuesday, November 21, 2023 1:18:50 PM(UTC)
epicycloid
Was thanked: 11 time(s) in 7 post(s)
Maybe there is a trick buried in the docs that I haven't found yet, but is there a way to maintain the starting point of a line, when I type in a length for it?
I'm still new to ViaCAD and migrating from my prior software, so things work a little differently...
The scenario is I draw a line, and I want to draw the next line, starting at the endpoint of the first line, but enter a specific length for it.
What happens is the LogiCursor enable starting on the endpoint of the first line, and I draw out an approximate distance. But then when I type the desired length in the data entry, the line adjusts to the correct length, but jumps off the starting pojnt.
This seems very counterintuitive, and I'm guessing it must be pilot error on my part.
How can I draw a line, and maintain it's initial position, when entering a value for it?
2 images attached showing where the line starts, then entering a length of 3' and how it "jumps" off of the desired endpoint of the other line.
Edited by user Tuesday, November 21, 2023 1:20:55 PM(UTC)  | Reason: Not specified
epicycloid attached the following image(s):
      --Jon
SharkCAD Pro – V14 (aka 14.1.0 = WIP 1641 or 1645 or 1654)
16" MacBook Pro – M2 Pro – MacOS Ventura 13.6.7
#2 Posted : Tuesday, November 21, 2023 4:04:46 PM(UTC)
Try the Multi-Line tool.
Tab to cycle through fields, CR to enter values as a line segment.
Edited by user Tuesday, November 21, 2023 4:05:40 PM(UTC)  | Reason: Not specified
multiline.mp4 (3,768kb) downloaded 4 time(s).
#3 Posted : Wednesday, November 22, 2023 8:24:28 AM(UTC)
Was thanked: 202 time(s) in 140 post(s)
That's crazy, I've never seen such behavior before. Is this a new bug in Version 14? In SharkCAD and ViaCAD, the correct principle for drawing a line is to first draw the line and then define its length.
#4 Posted : Wednesday, November 22, 2023 9:03:21 AM(UTC)
Yes, that is the way it is working. I would need steps that show otherwise. Length is defined in the direction of P2 - P1.
epicycloid
#5 Posted : Wednesday, November 22, 2023 12:48:54 PM(UTC)
epicycloid
Well, I used the line example as the simplest case of where I see this happen, but it happens on other tools too.
And I apologize for posting my two images in the wrong order, the right image is the initial case, the left image is the result.
Steps to reproduce:
1. Draw a line (I drew a vertical line, but any angle does the same)
2. Start drawing a second line, with the LogiCursor indicating "endpoint" of the first line (I drew a horizontal line, perpendicular to the first, likewise, any angle does the same)
3. Click to end the new line.
4. Start typing a length, which will automatically highlight and enter the text in the Length data entry field (I typed 4' --> number 4 and single quote for feet, using feet/inches units)
5. Hit return, and new line jumps off of the endpoint of the first line.
Alarmingly, Tim's suggestion of trying the Multi-Line tool exhibits the same behavior...
1. Start drawing a line
2. Before clicking to place the second point, type 2' and hit return
3. On mouse movement, line and cursor jump
--> The first attached image shows a sequence of drawing arbitrary angled lines, and entering 2' before clicking the endpoint.
Then I tried a variation, manually dragging out to 2' a couple times on the first two line segments, then on the third typing in the 2' value, and the multi-line jumps off the end of the first two (well behaved) lines. Screen shot attached.
--> The second screenshot sows a multi-line created by dragging out manually to 2' twice, then typing the 2' value for the third line.
Edited by user Wednesday, November 22, 2023 12:53:04 PM(UTC)  | Reason: Not specified
Multi-Line CCW-2ft.jpg (37kb) downloaded 2 time(s).
      --Jon
epicycloid
#6 Posted : Wednesday, November 22, 2023 1:05:39 PM(UTC)
epicycloid
I can email a (crummy) video showing the sequence if that helps.
I haven't tried any screen recording apps / tools, but if there is (a Mac) one that works, happy to try that too.
      --Jon
#7 Posted : Wednesday, November 22, 2023 2:16:40 PM(UTC)
Hello,
The easiest way to capture a video on a Mac is to use Quicktime (File menu, 3rd line : record screen)
#8 Posted : Thursday, November 23, 2023 6:51:23 AM(UTC)
WThe first attached image shows a sequence of drawing arbitrary angled lines, and entering 2' before clicking the endpoint.
The only working method is to first set an endpoint before entering the length. It's important to check which input field is active at the top of the screen.
Edited by user Thursday, November 23, 2023 7:02:07 AM(UTC)  | Reason: Not specified
epicycloid
#9 Posted : Thursday, November 23, 2023 12:45:57 PM(UTC)
epicycloid
Thank you, and yes, I understand that is how it is expected to work. That is why I asked my question... it isn't working that way for me at the moment.
Attached is an example where I...
1. Drew a circle
2. Started a vertical line with LogiCursor saying it was in the center
3. Clicked to place the endpoint of the first line
4. Then used the tab key to highlight the "Length" field
5. Typed 3' and hit return
6. The line "jumped" out of the circle, up and to the right
7. I started a second horizontal new line, with the LogiCursor saying it was on the "endpoint" of the first line
8. I dragged and clicked to set the finishing point to the right of the start point
9. I typed tab until the "Length" field was highlighted
10. I typed 3' and hit return, the still highlighted red line shows where that line jumped to
I am using WIP 1641. I will install another version to try and reproduce and see if this is a recent change in behavior.
There was also a recent fix to the feet/inches and for troubleshooting purposes I will test to see if this happens in other units (I am currently working on architectural drawings in feet/inches).
More to follow.
      --Jon
epicycloid
#10 Posted : Thursday, November 23, 2023 12:52:19 PM(UTC)
epicycloid
Well, low and behold, my suspicion that this might be related to a previous issue that I was seeing prior to WIP 1641... when I tried the very same sequence of events in MM instead of feet/inches, everything worked as expected.
Attached is a screenshot of the same steps, with the only change being to switch from feet/inches to MM...
Time permitting I will install an older build and see if feet/inches behaves as expected.
Edited by user Thursday, November 23, 2023 12:52:49 PM(UTC)  | Reason: Missing new attachment
      --Jon
thanks 1 user thanked epicycloid for this useful post.
MPSchmied on 11/24/2023(UTC)
epicycloid
#11 Posted : Friday, November 24, 2023 1:26:43 PM(UTC)
epicycloid
Thanks for the comments. Initially I thought I was going crazy...
I filed a bug report on this, as I was able to reproduce it in ViaCAD and now SharkCAD.
With further testing, it seems to be specific to working in units of feet/inches, and doesn't appear to happen in any of the other units I tested.
I suspect this crept in with the recent WIP build that fixed the data entry field, when working in feet/inches.
      --Jon
#12 Posted : Saturday, November 25, 2023 10:29:30 AM(UTC)
That's not necessary. You only need Tab in exceptional cases or if you want to edit other fields, because the field for the length is active by default, even if it is not highlighted in color. To clarify, the value in the length field is not initially highlighted in color, but you can still immediately edit the value after setting the endpoint.
epicycloid
#13 Posted : Friday, December 1, 2023 4:14:38 PM(UTC)
epicycloid
Yes, I know that the tab is unnecessary *most* of the time, for the "expected case" like changing the length.
I was merely trying to be sure I followed Tim's suggestion above, so as not to add yet another variable in the attempt to troubleshoot or reproduce the issue.
So far, with my ongoing testing, this still appears limited to working in feet/inches only.
Edited by user Friday, December 1, 2023 4:15:33 PM(UTC)  | Reason: clean up quote
      --Jon
epicycloid
#14 Posted : Thursday, June 27, 2024 2:13:02 PM(UTC)
epicycloid
Resurrecting this older topic... Can anyone else please confirm the same behavior I am seeing...
- Set units to "feet",
- Draw a line, type a length, hit return / enter,
- Draw a second line, using an endpoint of the first line as the starting point, type a length and hit enter -- the new line grows (or shrinks) from the start point, as expected
- Set units to "feet/inches",
- Draw a line, type a length, hit return / enter, -- my line "jumps" from whatever position it is drawn in to a new position
- Draw a second line, using an endpoint of the first line as a starting point, type a length and hit return / enter -- my line jumps from the designated starting point, it changes length, but moves to an unexpected new position
I just tried this again in WIP 1645, and the behavior is the same as it was in WIP 1641.
I am trying to work on architectural drawings, and sure I *could* work in "feet" or in "inches", but all the drawings, and ultimately all the dimensions, are expressed in "feet/inches".
Thanks for reading / trying the above,
      --Jon
epicycloid
#15 Posted : Thursday, June 27, 2024 2:33:10 PM(UTC)
epicycloid
And just to confirm, per Tim's earlier comment, the behavior is just as weird using the multi-line tool. Every time I hit return / enter, the line jumps from where it was drawn.
As far as I can tell, this still *only* affects drawing in the feet/inch mode. All other modes seem to work as expected.
      --Jon
epicycloid
#16 Posted : Thursday, June 27, 2024 4:24:58 PM(UTC)
epicycloid
And just to be sure I'm not too far out of date, I just downloaded and installed SharkCAD Pro 1654, same behavior.
      --Jon
#17 Posted : Friday, June 28, 2024 4:17:03 AM(UTC)
I tested this in version 9 and version 10. In these versions, the problem does not occur after changing the units to inches in the preferences.The higher the version, the more bugs. When does it end?
damhave on 6/28/2024(UTC)
mitchb
#18 Posted : Saturday, June 29, 2024 5:47:20 PM(UTC)
mitchb
Was thanked: 76 time(s) in 38 post(s)
The problem that is causing this is a bad format in the data boxes. The correct format in feet/inches when using fractions is, for example 2' 6 1/2". In the data box the format for this dimension is 2' 6" 1/2. Note the inch mark is right after the inch but before the fraction, this will cause the parser to fail. All the data boxes and the Inspector have this wrong format. Needs to be fixed ASAP.
thanks 3 users thanked mitchb for this useful post.
MPSchmied on 6/29/2024(UTC), damhave on 6/29/2024(UTC), GARLIC on 6/30/2024(UTC)
epicycloid
#19 Posted : Tuesday, July 2, 2024 10:32:44 AM(UTC)
epicycloid
This bug occurs without using fractions, just whole number, e.g. 6' 4" will cause the line to jump from the drawn position.
Edited by user Tuesday, July 2, 2024 10:33:22 AM(UTC)  | Reason: Not specified
      --Jon
epicycloid
#20 Posted : Tuesday, July 2, 2024 10:36:23 AM(UTC)
epicycloid
This behavior only occurs when the units are set to feet / inches.
In my case, although it is painful, I have just moved to using inches until this is fixed.
Edited by user Tuesday, July 2, 2024 10:37:11 AM(UTC)  | Reason: shorten quote
      --Jon
MPSchmied on 7/2/2024(UTC)
Guest (11)
2 Pages12>
