Art
#1 Posted : Wednesday, November 15, 2023 11:55:25 AM(UTC)
Art
Starting about a month ago I wrote Punch about a problem that I was having with I am using Sharkcad Pro version 14.1.0 build 1635. on a mac running 10.13.6 with 48 gb ram.
I have sent videos showing that with no parts, just the application open, it crashes upon hitting "render". As far as I know the rest of the application works with no problems. I have gone back to using Shark Pro 11.
I have been using this product and its predecessors for somewhere around 25 years and have come to expect responsive support.
I am now receiving no responses from U.Zubair, Punch Software | QA/Support Engineer and wonder what I should expect as far as resolution of this problem.
#2 Posted : Saturday, November 18, 2023 1:56:49 PM(UTC)
Hello Art
It sounds like something may be corrupt with the install. Can you rename your current build (ie add 1635) and download the 1641 build from:
http://www.masterviacad.com/beta/beta.php
If 1641 still crashes, we can try something else...
Art
#3 Posted : Wednesday, November 22, 2023 4:29:54 PM(UTC)
Art
Thanks Tim!
Unfortunately, the exact same crash occurs. It crashes immediately when I touch render, otherwise stable. I have never had this problem using SharkCad Pro 11.
Art
I just tried 1635 with my 2012 Macbook Pro running 10.13.6 (16gb) and the exact same crash occurs. Nobody else is having this problem? I cannot be the only user with Jalopy computers. Again, the Macbook is totally stable and happy with Shark Pro 11.
Edited by user Wednesday, November 22, 2023 4:37:39 PM(UTC)  | Reason: Not specified
#4 Posted : Thursday, November 23, 2023 1:42:21 PM(UTC)
Art
Can you send me the log file mentioned in the email?
It might helps us track the location in the code.
Art
#5 Posted : Tuesday, December 5, 2023 6:31:58 AM(UTC)
Art
Did the log file help?
Art
Any Ideas? It has been over 6 weeks since I brought this up.
Edited by user Wednesday, December 20, 2023 10:50:17 AM(UTC)  | Reason: Not specified
thanks 1 user thanked Art for this useful post.
damhave on 12/5/2023(UTC)
Art
#6 Posted : Tuesday, January 23, 2024 10:45:01 AM(UTC)
Art
It has more than 2 months and I am still using SharkCad 11.
No Ideas?
damhave on 1/24/2024(UTC)
Art
#7 Posted : Thursday, February 15, 2024 12:10:07 PM(UTC)
Art
Hello?
damhave on 2/15/2024(UTC)
#8 Posted : Friday, February 16, 2024 5:32:23 PM(UTC)
Hello Art
I suspect the issue is related to your hardware board:
Device Name:ATI Radeon HD 5870
Do you have any options to disable via a user interface or system setting to confirm?
In 1649, I did make some changes wrt how the CPU/GPU is used where you might want to see if there is a difference.
