mcaliebe
#1 Posted : Tuesday, November 14, 2023 4:57:34 PM(UTC)
mcaliebe
I searched for this topic with luck. Apologies if this has been answered.
Is there a setting in dimension properties to increase the gap between the measurement text and the extension line? I can't seem to find one.
mcaliebe attached the following image(s):
Screenshot 2023-11-14 164800.png (17kb) downloaded 2 time(s).
rokoko
#2 Posted : Wednesday, November 15, 2023 11:12:20 AM(UTC)
rokoko
I only know the trick with a new line inside the text data entry of the dimension object. A backslash with a subsequent P creates a new line. See my 2 pictures, you can fill the new line with spaces to increase the gap at the end of the dimension. Unfortunately this doesn't work at the beginning
