mikeschn
#1 Posted : Sunday, November 5, 2023 2:36:04 PM(UTC)
mikeschn
Has anyone created any hotkeys for Viacad. I'm looking for ideas...
So far I have for Show->Hide...h (think "hide")
and for Show->Show All...u (think "unhide all")
Any other ideas?
creativecad
#2 Posted : Sunday, November 5, 2023 7:32:22 PM(UTC)
creativecad
Most Cad users use a bunch of shortcut keys. Here are some of mine.
l - line
o - offset curve
f - fillet curves
h - match face
m - mirror
c - circle
a - arc
x - trim
g - group objects
u - ungroup objects
O - sets workplane origin
P - pick 3 points workplane
F - Front workplane
S - side workplane
T - Top workplane
U - top view
B - Bottom view
L - left view
R - right view
Also right clicking will bring up commands like hide, show only, and several more.
Also, you can make a custom tool pallet with your most used tools. That helps a bunch.
ViaCad 10 Pro
ViaCad 9
Windows 10
thanks 3 users thanked creativecad for this useful post.
GARLIC on 11/6/2023(UTC), mikeschn on 11/6/2023(UTC), MPSchmied on 11/6/2023(UTC)
mikeschn
#3 Posted : Monday, November 6, 2023 4:12:51 AM(UTC)
mikeschn
Wow, there's some really good ideas there. Thanks for sharing...
Mike...
#4 Posted : Monday, November 6, 2023 9:13:24 PM(UTC)
Was thanked: 221 time(s) in 152 post(s)
You can also copy and edit the configuration file "C:\Users\%yourusername%\AppData\Local\Punch!\Shark FX\SFXShortcuts.ini".
Code:
[Shortcuts]
CurKeySetName=Shortcuts
Edit:Change Layer=F7 Ö
Edit:Deselect All=N
Edit:Group=y
Edit:Ungroup=<
File:Export=E
File:Import=I
File:Print Layout=P
File:Print SetUp=F13
Layers:Dec Display={
Layers:Inc Display=}
Layers:Isolate Layer=L
Line:HorzConst=H
Line:Single Line=k
Line:VertConst=V
Mesh:Toggle Mesh SubDivision=t
Planes:Select Objects=B
Planes:Show Work Plane=f
Selection:Select Tool=n
Edit:Remove Links=u
Selection:Tape Measure=p
Snap:Snap Anchor Point=A
Verify:Angle=v
Verify:Distance=h
Verify:Length=x
Verify:Properties=o
View:Flip View=e
View:Front View=w
View:Isometric View=q
View:Left View=a
View:Redraw Screen=r
View:Right View=d
View:Top View=s
View:Trimetric View=g
View:Work Plane=b
View:Zoom In=] ! '
View:Zoom Out=? # [
View:Zoom Select=j
Window:Concept Explorer=l
Window:Inspector Attributes=i
Window:Select Mask=m
[Tastaturkürzel]
CurKeySetName=Tastaturkürzel
Analyse:2 Punkt-Abstand=h
Analyse:Eigenschaften=o
Analyse:Länge=x
Analyse:Winkel=v
Ansicht:Ansicht links=a
Ansicht:Ansicht rechts=d
Ansicht:Ansicht umkehren=e
Ansicht:Arbeitsebene=b
Ansicht:Bildschirm auffrischen=r
Ansicht:Draufsicht=s
Ansicht:Isometrisch=q
Ansicht:Trimetrisch=g
Ansicht:Vorderansicht=w
Ansicht:Zoom In=] ! '
Ansicht:Zoom Markierung=j
Ansicht:Zoom Out=[ ? #
Bearbeiten:Alles demarkieren=N
Bearbeiten:Degruppieren=<
Bearbeiten:Gruppieren=y
Bearbeiten:Layer ändern=F7 Ö
Bearbeiten:Verknüpfungen aufheben=u
Datei:Druckereinrichtung=F13
Datei:Exportieren=E
Datei:Importieren=I
Datei:Seite einrichten =P
Ebenen:3 Punkte=G
Ebenen:Arbeitsebene einblenden=f
Ebenen:Objektebene=B
Fangfilter:Fangankerpunkt=A
Fenster:Auswahlmaske=m
Fenster:Concept Explorer=l
Fenster:Fangfilter=,
Fenster:Inspektor-Attribute=i
Layer:Abnehmende Anzeige={
Layer:Layer isoliert anzeigen=L
Layer:Zunehmende Anzeige=}
Linie:Einzellinie=k
Linie:Senkrechte Hilfslinie=V
Linie:Waagrechte Hilfslinie=H
Markieren:Messen=p
Markieren:Werkzeug wählen=n
Polygonnetz:Umschalten Polygonnetz Subdivision=t
Edited by user Monday, November 6, 2023 9:15:56 PM(UTC)  | Reason: Not specified
thanks 4 users thanked MPSchmied for this useful post.
GARLIC on 11/7/2023(UTC), mikeschn on 11/7/2023(UTC), damhave on 11/7/2023(UTC), creativecad on 11/7/2023(UTC)
mikeschn
#5 Posted : Tuesday, November 7, 2023 5:18:51 AM(UTC)
mikeschn
@MPSchmied
Do you have all those hotkeys memorized?
Mike...
#6 Posted : Tuesday, November 7, 2023 6:13:51 AM(UTC)
Yes, except for the default hotkeys. You learn quickly if you look up the hotkey every time you don't know it.
mikeschn
#7 Posted : Tuesday, November 7, 2023 1:46:58 PM(UTC)
mikeschn
@MPSchmied
LOL, I guess so!
Mike...
rokoko
#8 Posted : Wednesday, November 8, 2023 12:40:50 PM(UTC)
rokoko
for Dynamic Rotate I use #
for Deselect All I use the digit 0
mikeschn on 11/8/2023(UTC)
mikeschn
#9 Posted : Wednesday, November 8, 2023 3:40:01 PM(UTC)
mikeschn
@rokoko,
Oh, deselect all - 0 is a good one too!
Mike...
