Have you created any hotkeys for Viacad?
Has anyone created any hotkeys for Viacad. I'm looking for ideas... So far I have for Show->Hide...h (think "hide") and for Show->Show All...u (think "unhide all") Any other ideas?
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
Most Cad users use a bunch of shortcut keys. Here are some of mine. l - line o - offset curve f - fillet curves h - match face m - mirror c - circle a - arc x - trim g - group objects u - ungroup objects O - sets workplane origin P - pick 3 points workplane F - Front workplane S - side workplane T - Top workplane U - top view B - Bottom view L - left view R - right view Also right clicking will bring up commands like hide, show only, and several more. Also, you can make a custom tool pallet with your most used tools. That helps a bunch.
ViaCad 10 Pro ViaCad 9 Windows 10
3 users thanked creativecad for this useful post.
Wow, there's some really good ideas there. Thanks for sharing... Mike...
Thanks: 341 times Was thanked: 221 time(s) in 152 post(s)
You can also copy and edit the configuration file "C:\Users\%yourusername%\AppData\Local\Punch!\Shark FX\SFXShortcuts.ini".
Code: [Shortcuts] CurKeySetName=Shortcuts Edit:Change Layer=F7 Ö Edit:Deselect All=N Edit:Group=y Edit:Ungroup=< File:Export=E File:Import=I File:Print Layout=P File:Print SetUp=F13 Layers:Dec Display={ Layers:Inc Display=} Layers:Isolate Layer=L Line:HorzConst=H Line:Single Line=k Line:VertConst=V Mesh:Toggle Mesh SubDivision=t Planes:Select Objects=B Planes:Show Work Plane=f Selection:Select Tool=n Edit:Remove Links=u Selection:Tape Measure=p Snap:Snap Anchor Point=A Verify:Angle=v Verify:Distance=h Verify:Length=x Verify:Properties=o View:Flip View=e View:Front View=w View:Isometric View=q View:Left View=a View:Redraw Screen=r View:Right View=d View:Top View=s View:Trimetric View=g View:Work Plane=b View:Zoom In=] ! ' View:Zoom Out=? # [ View:Zoom Select=j Window:Concept Explorer=l Window:Inspector Attributes=i Window:Select Mask=m [Tastaturkürzel] CurKeySetName=Tastaturkürzel Analyse:2 Punkt-Abstand=h Analyse:Eigenschaften=o Analyse:Länge=x Analyse:Winkel=v Ansicht:Ansicht links=a Ansicht:Ansicht rechts=d Ansicht:Ansicht umkehren=e Ansicht:Arbeitsebene=b Ansicht:Bildschirm auffrischen=r Ansicht:Draufsicht=s Ansicht:Isometrisch=q Ansicht:Trimetrisch=g Ansicht:Vorderansicht=w Ansicht:Zoom In=] ! ' Ansicht:Zoom Markierung=j Ansicht:Zoom Out=[ ? # Bearbeiten:Alles demarkieren=N Bearbeiten:Degruppieren=< Bearbeiten:Gruppieren=y Bearbeiten:Layer ändern=F7 Ö Bearbeiten:Verknüpfungen aufheben=u Datei:Druckereinrichtung=F13 Datei:Exportieren=E Datei:Importieren=I Datei:Seite einrichten =P Ebenen:3 Punkte=G Ebenen:Arbeitsebene einblenden=f Ebenen:Objektebene=B Fangfilter:Fangankerpunkt=A Fenster:Auswahlmaske=m Fenster:Concept Explorer=l Fenster:Fangfilter=, Fenster:Inspektor-Attribute=i Layer:Abnehmende Anzeige={ Layer:Layer isoliert anzeigen=L Layer:Zunehmende Anzeige=} Linie:Einzellinie=k Linie:Senkrechte Hilfslinie=V Linie:Waagrechte Hilfslinie=H Markieren:Messen=p Markieren:Werkzeug wählen=n Polygonnetz:Umschalten Polygonnetz Subdivision=t
Edited by user Monday, November 6, 2023 9:15:56 PM(UTC)
4 users thanked MPSchmied for this useful post.
@MPSchmied Do you have all those hotkeys memorized? Mike...
Originally Posted by: mikeschn Do you have all those hotkeys memorized?
Yes, except for the default hotkeys. You learn quickly if you look up the hotkey every time you don't know it.
@MPSchmied LOL, I guess so! Mike...
for Dynamic Rotate I use # for Deselect All I use the digit 0
1 user thanked rokoko for this useful post.
@rokoko, Oh, deselect all - 0 is a good one too! Thanks, Mike...
