#1 Posted : Friday, September 8, 2023 12:59:54 PM(UTC)
1641 Change Log
—Correct a corrupt files issue when importing files with variable equations into another file.
—Correct a crash when exporting a point with no xyz data
—Corrected a crash when joining helix splines together
—Correction related to supporting animation tools on Windows
-Print issues
—Photo Render dialog settings corrections
—Correction related to photo Photo Render backgrounds when null
—Thin extrude issue
Update available at :
http://www.masterviacad.com/beta/beta.php
Note this is a WIP and has not completed a full QA check.
jlm on 9/9/2023(UTC)
creativecad
#2 Posted : Wednesday, September 20, 2023 8:45:05 PM(UTC)
creativecad
This build 1641 is working very nice. No damaged files so far. I have only one crash when I imported some old AutoCAD files, but I worked around that no problem and no crashes since.
Does any other cad program on the market let you add or subtract your coordinates or the object size consecutively mid command like Viacad? Makes Viacad very fast. Not that I know of unless you set up constraints, but I'm not very experienced in many other cad programs.
ViaCad 10 Pro
ViaCad 9
Windows 10
thanks 1 user thanked creativecad for this useful post.
damhave on 9/21/2023(UTC)
sweboss
#3 Posted : Thursday, September 28, 2023 11:10:43 AM(UTC)
sweboss
Will version 14 and this WIP work with macOS 14 Sonoma?
