Thanks: 52 times Was thanked: 96 time(s) in 64 post(s)
Not sure if this is possible, but I'm trying to draw a bracket and model it in 3D.
I don't seem to be able to split the folded area, as the whole surface is folded, so in the end I had to create another folded part, rotate it and join the two solids.
Mike
Edited by user Tuesday, August 29, 2023 1:25:29 PM(UTC)
| Reason: Typo
(532kb) downloaded 22 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
I did a quick example, use separate bend lines, plus and - degrees, and always
bend on the centerline of the thickness.
Bends.sfx
(27kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Hi Larry
I never knew this about the middle bend line, I always thought you applied the line to the inside of the bend.
I'm going to redraw the part now, and apply your thinking.
Thanks again for taking the time to answer
Mike
(76kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Hi again Larry,
It wasn't as simple as I thought, took some attempts & undos before it managed it...
Mike
(168kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
