relaxibus
#1 Posted : Thursday, August 24, 2023 12:55:27 AM(UTC)
relaxibus
Was thanked: 78 time(s) in 44 post(s)
Hi, I'm not able to understand 90% of the Variable Blend functions.
I need to create a variable blend starting with a radius of 5mm to a center radius of 13mm down to 5mm again.
I have attached the sfx file and a screenshot.
NOTE: NOT ABLE TO UPLOAD the SFX or ZIP file!!
NOTE2: I was able to understood the "by position" function. However others are quite difficult to understand. Is there any complete tutorial about all the blend functions?
Edited by user Thursday, August 24, 2023 1:12:21 AM(UTC)  | Reason: Not specified
relaxibus attached the following image(s):
24c
#2 Posted : Thursday, August 24, 2023 8:53:10 AM(UTC)
24c
Was thanked: 70 time(s) in 51 post(s)
Hi @relaxibus
Not sure if these links might shed some light on Variable Blends
http://docs.imsidesign.c...ing/Feature-Based-Solid/
http://docs.imsidesign.c...eature-Based-Solids.html
Mike
macOS Tahoe - v16 beta
MPSchmied on 8/24/2023(UTC)
#3 Posted : Thursday, August 24, 2023 9:52:36 AM(UTC)
File might be too big. Can you select the solid, copy, open new drawing, paste and upload that file?
relaxibus
#4 Posted : Friday, August 25, 2023 1:17:57 AM(UTC)
relaxibus
Hi Tim,
the file was not too big, 6MB in sfx format. Tried with Safari and Firefox. Anyway I resolved the variable blend, it was not not soo easy to understand how this works and you need to select all edges with "shift" and then place the points with the different radius values.
Funny was that with a radius >10mm, shelling was not working, <10mm shelling was working.
