ViaCAD, SharkCAD, TurboCAD Mac 14 Build 1632 is ready for WIP testing. You can receive links from:
http://www.masterviacad.com/beta/beta.php Change Log 1632 —Correction converting text labels to numbers from V12 to V14
—Remove error dialog while calculation planar text polygons in repaint
—Correction for sweep profile on rails consisting of multiple paths CRASH
—Correction for sweep curves on rails consisting of multiple paths CRASH
—Correction inverting texture coordinates from read OBJ then write OBJ
Edited by user Tuesday, May 23, 2023 1:05:10 PM(UTC)
Was thanked: 28 time(s) in 15 post(s)
Mac exclusive or Win too?
Thanks: 52 times Was thanked: 96 time(s) in 64 post(s)
@murrayagain both platforms available Mike
Thanks: 645 times Was thanked: 105 time(s) in 67 post(s)
it would be quite useful to know what has been fixed / improved, any listing available ??? G.
2 users thanked GARLIC for this useful post.
- Perspective still not working - Unable to link with KeyShot
1 user thanked Jean-Francois Jacques for this useful post.
>>]it would be quite useful to know what has been fixed / improved, any listing available ??? added to original post.... Tim
2 users thanked Tim Olson for this useful post.
Thanks for that @Tim I had issues with sweeps in a model a while back, and I thought it was me. :) Mike
>>I had issues with sweeps in a model a while back, and I thought it was me. :) It was pretty messed up due to some changes in ACIS between V12 and V14. Tim
24c on 5/23/2023(UTC),
GARLIC on 5/24/2023(UTC)
Thanks: 7 times Was thanked: 91 time(s) in 51 post(s)
is 3D PDF export now working?
@relaxibus Not for me... I tried exporting from SharkCAD Pro and in macOS and Adobe Acrobat Reader no joy. Another program threw up an error message, not recognising the file format "possibly 3UD" Mike
Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
“Scale values with text size” function doesn’t work properly.
- Open SharkCAD 14 v1632 and draw a line
- Dimension the line with default text size
- Now change the text size and dimension the same line again
New dimension will have different text size but all other values remain unchanged (not scaled) !!!
Edited by user Thursday, May 25, 2023 6:27:54 PM(UTC)
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
1 user thanked Mark for this useful post.
Originally Posted by: relaxibus is 3D PDF export now working?
Yes. The correction should be available in 1633 builds.
