updates always with work
Thanks: 16 times Was thanked: 4 time(s) in 4 post(s)
hello, i'm wondering. Every update with Viacad Pro and Shark pro, i have to update the folder of Symbols and material. i remeber some versions i had to add silver and gold and platin etcc in the properties list, later i was happy, they added it . Now i am sad, they don't have it any more and i have to edit it by myself again. Symbols i have to ad with every update by hand. Model to sheet i have to update by hand. I would wish to have this folders includet with the updates. because i'm very lazy :-) at least, please ad the siler and different gold properties again Thank you i'm hopefully Andreas
Andreas >>i had to add silver and gold and platin etcc in the properties list, Can you email me your properties list. Tim
Thanks: 264 times Was thanked: 131 time(s) in 101 post(s)
Originally Posted by: a.wieneke Model to sheet i have to update by hand.
Most files are located in the program folder under \Punch! Software\SharkCAD 14\Templates, including the MTS files. Additionally, there are the "Environ" and "Symbols" folders. You can easily copy the files, as well as the user settings, from an older Punch!CAD version to the new one. This even works when upgrading from Version 9 to Version 14.
Originally Posted by: Tim Olson Andreas >>i had to add silver and gold and platin etcc in the properties list, Can you email me your properties list. Tim
yes, this eveneing, when i'm back home on my older computer
