Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
                I try to figure out how to use the Insert Group Tool in the Architectural section. As I understand from the manual I should make a group containing for example a wall with different attachments, such as windows and doors. Then choose the tool, pick the wall where I want to place the group, pick th group and the point on the position of the wall where I want to place the group. This is exactly what I try to do, but as you can see in the attached screen recording, the result is quite unexpected.
I'm running ver 14 Deluxe on a MacBook Pro 15-2018 with Ventura 13.2.1
 Insert Group.mp4
(3,396kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
