anthrotech
#1 Posted : Wednesday, February 15, 2023 4:50:24 AM(UTC)
anthrotech
I'm trying to export (V 12, selected only checked) from a sheet view to DXF or DWG for laser cutting.
Hiding the layers with title block and dimensions works in SharkCAD, however the dimensions appear in the DXF and DWG. The title block does not.
Am I missing something or is this a bug? Is there any workaround other than deleting all dimensions before export?
SharkCAD 14 Pro, iMac (Retina 4K, 21.5-inch, 2017) 3,4 GHz Quad-Core Intel Core i5, MacOS BigSur 11.4, dual screen setup
#2 Posted : Wednesday, February 15, 2023 10:41:23 AM(UTC)
DXF/DWG by design exports the entire file including layers.
You could try exporting "Selected Only".
#3 Posted : Friday, February 17, 2023 2:32:28 AM(UTC)
Originally Posted by: anthrotech Go to Quoted Post
) from a sheet view
make sure, that your sheet view is not scaled. Otherwise your dxf-export will be also scaled but nobody know the scale and you get a wrong sized laser cutting.
damhave on 2/17/2023(UTC)
anthrotech
#4 Posted : Tuesday, February 21, 2023 2:18:47 AM(UTC)
anthrotech
I checked "selected only". The DXF contains all layers (that could be fixed), dimensions and drawing end up in the same DXF layer "sheet view drawing1", a dimensions layer is not in the DXF. So it is impossible to turn off dimensions. Anyway, they should not be there.
Matthias
anthrotech
#5 Posted : Tuesday, February 21, 2023 2:21:27 AM(UTC)
anthrotech
) from a sheet view
Yes, I noticed that. Has been this way for years, could be fixed eventually. I'm using 1:1 A3, A2 etc sheets for laser cutting...
Matthias
thanks 1 user thanked anthrotech for this useful post.
damhave on 2/21/2023(UTC)
