                This simple task is really giving me a fit.
                I think I just figured out what is giving me a problem. I want to use a special font using the dimension tools. It looks like it won't stay on the font I want using the dimension tools. Kind of a bummer. I might be missing something. But normally using text I have not seen this. I just realized it must just not work with the dimension's. I will just have to enter the font and text size every time.
                There is dimension text properties and then text properties.  Make sure nothing is selected (the top of the inspector will say New). Set the size and style of your text in the text properties, not the dimension text properties.
    ViaCad 10 Pro
             2 users thanked creativecad for this useful post.
                Use dimension text properties to set dimension text properties, and text properties for text that is not dimensions.  If "scale dimensions by text size is selected", then the dimension properties will scale bigger or smaller if you increase or decrease its current font size.
    ViaCad 10 Pro
             1 user thanked creativecad for this useful post.
                Thank you so much for that tip creativecad.
Reading your explanation, I can tell I was not doing that quite right. Thanks again.
p.s. I always like to use custom fonts that are not necessarily called true type fonts.
Many Cad programs don't like some of the custom fonts I like to use.
So many times when certain features don't work I always think it could be these custom fonts.
Your explanation was great.
Edited by user  Friday, February 3, 2023 2:11:36 PM(UTC)
 | Reason: additional thoughts
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
