ctkjose
#1 Posted : Friday, January 27, 2023 9:51:29 PM(UTC)
ctkjose
I ll use this thread to post issues I find.
1. PowerPack "Reduce Triangles" crashes. I may be using it wrong! (Im working on a fairly simple mesh imported from an STL)
<code>
Translated Report (Full Report Below)
Process: ViaCAD 14 [64270]
Path: /Applications/ViaCAD 14.app/Contents/MacOS/ViaCAD 14
Identifier: com.encore.viacad14esd
Version: 14.0.0 (1616)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-01-27 23:11:04.4384 -0400
OS Version: macOS 12.3 (21E230)
Report Version: 12
Anonymous UUID: AA0CC10D-4B8A-785D-3EC5-E504C3FCF3DA
Sleep/Wake UUID: 4827D1E8-6610-4752-85EE-D14001A27026
Time Awake Since Boot: 3900000 seconds
Time Since Wake: 5238 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000068
Exception Codes: 0x0000000000000001, 0x0000000000000068
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [64270]
VM Region Info: 0x68 is not in any region. Bytes before following region: 4342833048
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 102da6000-107c5e000 [ 78.7M] r-x/r-x SM=COW ...cOS/ViaCAD 14
Application Specific Information:
Performing @selector(pushButtonChanged:) from sender NSButton 0x7f94fa90fef0
Kernel Triage:
VM - pmap_enter failed with resource shortage
</code>
thanks 1 user thanked ctkjose for this useful post.
specktech on 1/31/2023(UTC)
#2 Posted : Saturday, January 28, 2023 1:14:59 AM(UTC)
That's always been the case. It's never worked right.
#3 Posted : Saturday, January 28, 2023 1:52:58 AM(UTC)
Can you post or private email the file?
