#1 Posted : Tuesday, January 24, 2023 8:19:24 PM(UTC)
Was thanked: 117 time(s) in 78 post(s)
How do I do in SharkCAD V12 PP what is done starting at 4m 51s? The "Spin" tool.
"Watch "5 Blender Tools I Wish I Knew when I Started..." on YouTube"
https://youtu.be/jHgT7VU5mD4
For years, I either started with a crve and surface, or a curve and pipe.
Also, starting witha primitive or a sample surface based on a circle, how do I extrude a surface up, then freeform introduce bends that do smooth radiuses so I don't have to in advance plane a route so that I get a pipe that is not wacky?
Here is more on the Spin tool:
"Watch "Blender 2.8 - Spin Tool - Tutorial" on YouTube"
https://youtu.be/OcESDOixsj0
That's from 3 years ago. I'm today struggling to replicate that in SharkCAD v12 PP. I want to so it with surfaces and solids. I'm not crazy about meshes yet.
Does anyone know of any ViaCAD or SharkCAD tutorials for doing that?
Thanks.
Something I finally today after 10 years figured out and like is the deep-select rotate. Tho, it doesn't like working on many of the chamfers and bevels and blended edges I put on primitive blocks and cylinders.
thanks 1 user thanked ZeroLengthCurve for this useful post.
specktech on 1/26/2023(UTC)
#2 Posted : Tuesday, January 24, 2023 9:01:01 PM(UTC)
Try the Extend Bend tool. This is using ACIS bend API procedures (no mesh, precise solids).
http://www.csi-concepts....ideos/v14/extendbend.mp4
Edited by user Tuesday, January 24, 2023 9:02:24 PM(UTC)  | Reason: Not specified
thanks 3 users thanked Tim Olson for this useful post.
GARLIC on 1/25/2023(UTC), ZeroLengthCurve on 1/25/2023(UTC), specktech on 1/26/2023(UTC)
#3 Posted : Wednesday, January 25, 2023 2:25:25 AM(UTC)
Thanks, Tim.
I'll try again.
A week or two ago, on a lark/distraction, I bent things and was impressed. IIRC, I only bent flat plate, not a pile.
Yesterday, when intentionally trying to bend a solid, a mesh, and a surface, whether with the Gripper or the Bend tool, I got compressed/distorted results by Gripper and got error messages by the Bend tool.
I checked the filter and snap settings, did get contact, but noted that with and without a guide curve, whether a regular line of 2 or 3 points, or a spline of 4 points (2 coincident at a vertex, to make a 90-degree bend), I repeatedly met with failure.
I'll try again.
But, It would be nice to have a Gripper visual reference. I will try with neat interpolated splines in various shapes against various objects.
#4 Posted : Wednesday, January 25, 2023 2:32:08 AM(UTC)
Wow!
That's crazy-simple. That's EXACTLY what I'm after. I'm embarrassed. I should have been more resourceful, and I should have figured that out.
Yesterday, I tried a different way, to mimic the Blender vid by using the Gripper and a placeholder circle, and by setting the origin to the circle, and by rotating about the center. That only resulted in a drag across like a chord move.
Again, THANKS!
#5 Posted : Wednesday, January 25, 2023 3:48:44 AM(UTC)
Success!
Thanks!
#6 Posted : Wednesday, January 25, 2023 3:19:14 PM(UTC)
>>Thanks!
Awesome. As a precision tool, I think it's hopefully much better than Blender. I use blender quite a bit for rendering and Lux testing but everything is facets/triangles.
And it's a pretty interesting tool for duct and pipe design. IE precision, associative, and feature tree supporting tool.
Edited by user Wednesday, January 25, 2023 3:34:23 PM(UTC)  | Reason: Not specified
thanks 2 users thanked Tim Olson for this useful post.
specktech on 1/26/2023(UTC), MPSchmied on 2/1/2023(UTC)
Guest (6)
