la mouche
#1 Posted : Wednesday, June 3, 2009 8:12:23 AM(UTC)
la mouche
Hello,
can you please explain this message?
Normally, the shell should be possible
see the attach file please.
Antoine
#2 Posted : Wednesday, June 3, 2009 1:15:35 PM(UTC)
It is unable to shell the body because it cannot create the offset of the faces. Looking at the image, possibly because of self intersections of the offsetted face. It might work at a smaller thickness value.
unique
#3 Posted : Saturday, June 6, 2009 11:00:27 AM(UTC)
unique
Originally Posted by: la mouche Go to Quoted Post
Hello,
Antoine
Hi Antoine,
If possible, post your model and I will see if it is possible with a parasolid engine as well as in spaceclaim ?
la mouche
#4 Posted : Tuesday, June 9, 2009 5:51:43 AM(UTC)
la mouche
hello Paul,
Thanks.
Here the file. arf not possible upload... 2,9 MB
Tim?
look my history, i think, my model is good.
Antoine
la mouche
#5 Posted : Tuesday, June 9, 2009 7:45:56 AM(UTC)
la mouche
hello,
another file
Tanks for your test and reply.
Antoine
shell2.sfx (424kb) downloaded 5 time(s).
shell 2.jpg (180kb) downloaded 5 time(s).
Steve.M
#6 Posted : Tuesday, June 9, 2009 8:44:31 AM(UTC)
Steve.M
hello,
another file
Antoine
Hi Antoine,
The model as many errors. Use the "verify- Check object"
- Steve
Steve.M
#7 Posted : Tuesday, June 9, 2009 10:42:52 AM(UTC)
Steve.M
another file
Antoine
Hi Antoine,
I rebuilt the solid in VC pro. It will now shell OK.
- Steve
shell.vcp (198kb) downloaded 5 time(s).
la mouche
#8 Posted : Wednesday, June 10, 2009 2:09:33 AM(UTC)
la mouche
hello, Stevve
Thanks for your reply.
But.. your model is make with surfaces.
looong work.
Steve.M
#9 Posted : Wednesday, June 10, 2009 3:25:39 AM(UTC)
Steve.M
looong work.
Hi Antoine,
Yes, it took about 30 minutes for what should of been under 5. The problems with the sweeps/guides really needs to be fixed.
I made the model the way I did to show that the shelling can be done if the model is correct, it is just that if the model is created by guide skin surfaces/solids then the model (in quite a lot of instances in the type of closed shape you want) will not be shelled due to bad curvature created by VC/Shark.
- Steve
la mouche
#10 Posted : Wednesday, June 10, 2009 3:39:03 AM(UTC)
la mouche
merci Steve.
Antoine
la mouche
#11 Posted : Wednesday, June 10, 2009 5:46:41 AM(UTC)
la mouche
also with Safari
Antoine
#12 Posted : Tuesday, June 30, 2009 12:03:56 AM(UTC)
hello,
another file
Antoine
Hi Antoine,
Read your shell2.sfx file into any of the 838 builds and do a Force Resolve Links. Your shell should work then.
http://www.csi-concepts.com/Demo/videos/noShell2.mov
la mouche
#13 Posted : Tuesday, June 30, 2009 3:21:03 AM(UTC)
la mouche
hello Tim,
Thanks very much!
Antoine
