                Hello,
can you please explain this message?
Normally, the shell should be possible
see the attach file please.
Antoine
(72kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by:  la mouche  Hello,
Hi Antoine,
If possible, post your model and I will see if it is possible with a parasolid engine as well as in spaceclaim ?
                hello Paul,
Thanks.
Here the file. arf not possible upload... 2,9 MB
Tim?
look my history, i think, my model is good.
Antoine
(52kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                hello,
another file
Tanks for your test and reply.
Antoine
 shell2.sfx
(424kb) downloaded 5  time(s). la mouche attached the following image(s):
(180kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by:  la mouche  hello,
Hi Antoine,
The model as many errors. Use the "verify- Check object"
- Steve
                Originally Posted by:  la mouche  another file
Hi Antoine,
I rebuilt the solid in VC pro. It will now shell OK.
- Steve
 shell.vcp
(198kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                hello, Stevve
                Originally Posted by:  la mouche  But.. your model is make with surfaces.
Hi Antoine,
Yes, it took about 30 minutes for what should of been under 5. The problems with the sweeps/guides really needs to be fixed.
I made the model the way I did to show that the shelling can be done if the model is correct, it is just that if the model is created by guide skin surfaces/solids then the model  (in quite a lot of instances in the type of closed shape you want) will not be shelled due to bad curvature created by VC/Shark.
- Steve
Hi Antoine,
Read your shell2.sfx file into any of the 838 builds and do a Force Resolve Links.  Your shell should work then.
http://www.csi-concepts.com/Demo/videos/noShell2.mov Regards
                hello Tim,
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
