Maarten den Hartog
#1 Posted : Thursday, January 12, 2023 10:07:24 AM(UTC)
Maarten den Hartog
Was thanked: 4 time(s) in 2 post(s)
Now I see that Shark v14 has some kind of animation with the "Auto Explode VCR", it is time to have some kind of simple on screen animation of moving parts.
This will greatly help verify the movements of a design.
Imagine like this:
1. select (on screen) animation
2. select the parts you want to animate. These part are then copied as instance in a new animation layer
3. Move/rotate/scale the parts to their end position.
4. Give the layer an animation window with: play, loop, rebound etc. And give the animation window a slider that the controls the animation.
5. Move/rotate/scale can be edited in the Concept explorer->entities by typing a new rotation, move scale.
Thank you for reviewing this request.
