Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I am wanting to add curved text along a the top of a gate. The text on the left is correct, but on the right it put the letters in backwards. How do I fix this?
Dyn_Metalworks attached the following image(s):
(49kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked Dyn_Metalworks for this useful post.
Text is based on the start location of the curve. Try Edit : Change Direction on the curve with the backwards text. Tim
Originally Posted by: Tim Olson Text is based on the start location of the curve. Try Edit : Change Direction on the curve with the backwards text. Tim
That worked, thanks!
