Mogal
#1 Posted : Friday, November 18, 2022 11:40:25 AM(UTC)
Mogal
Hello, I want to put text on my project, and for the most part its working.
BUT!!! The text gets projected on EVERY WALL through the project making it really difficult
to work the text after it's been projected.
I'm wanting to emboss on all four sides, but with everything projecting through,
makes it next to impossible.
How can I project the text and then emboss it on all four sides without the interference
of the opposite's side projection?
Thanks!
https://ibb.co/XbNGCMY
Edited by user Friday, November 18, 2022 11:41:20 AM(UTC)  | Reason: Not specified
Mogal
#2 Posted : Friday, November 18, 2022 11:47:49 AM(UTC)
Mogal
See if I can attach my file...
This will be 3d printed. (It's for a remote Emerge Stop Button for the CNC machine)
Edited by user Friday, November 18, 2022 12:10:57 PM(UTC)  | Reason: Not specified
Emerg Stop 3.vcp (2,916kb) downloaded 6 time(s).
rockyroad_us
#3 Posted : Friday, November 18, 2022 2:24:22 PM(UTC)
rockyroad_us
the imprint feature goes through all the walls. You will have to delete the ones you don't want with the remove face feature in solids. Alternatively, you should be using the wrap text feature. I believe it is in viacad. I use the pro.
The wrap feature should be easier.
thanks 1 user thanked rockyroad_us for this useful post.
specktech on 12/30/2022(UTC)
Mogal
#4 Posted : Friday, November 18, 2022 8:13:36 PM(UTC)
Mogal
Thanks, I am still on v10pro with PP, and not really planning on upgrading.
My work around for now is to cut the object into 1/4s diagonally.
Do the text work I want to do, the fuse them back up.
Not optimal, but works.
Thanks.
thanks 1 user thanked Mogal for this useful post.
mitchb
#5 Posted : Friday, November 18, 2022 9:21:16 PM(UTC)
mitchb
Was thanked: 73 time(s) in 36 post(s)
Move your text so that it is inside your object then project it out to the surface.
thanks 2 users thanked mitchb for this useful post.
GARLIC on 11/19/2022(UTC), specktech on 12/30/2022(UTC)
Mogal
#6 Posted : Tuesday, January 3, 2023 11:08:35 PM(UTC)
Mogal
Thanks! I hate it when the solution is so easy and my head just can't see it.
specktech on 1/4/2023(UTC)
specktech
#7 Posted : Wednesday, January 4, 2023 9:02:50 PM(UTC)
specktech
Awesome tip "mitchb" I was trying to figure this out awhile back as well. Going to go try it. Thanks for that tip.
Guest (6)
