Rob Rongstad
#1 Posted : Tuesday, October 11, 2022 9:15:05 AM(UTC)
Rob Rongstad
I'm running SharkCAD 12.0.7 Build(1572) on MacOS 12.6. Suddenly I can't get the layers in Concept Explorer to work. I have a design with many layers but the only layers that show up are Construction, Dimension and Layer1. I can see all of the layers in the selection mask and I can see and move all layers in Object Properties but not in the layers window. I have restarted SharkCAD and also rebooted my system with no change.
#2 Posted : Tuesday, October 11, 2022 9:36:20 AM(UTC)
Is this a import from an other CAD-Software? Maybe in this "design" are to many layers. Sometimes after DXF-Import are the Layers of the import invisible in Concept Explorer. What happens when you select a part? Is then the layer of the selected part visible in Concept Explorer?
Maybe you imported to many layers. To many objects and to many layers - not good for SharkCAD.
Edited by user Tuesday, October 11, 2022 10:07:46 AM(UTC)  | Reason: Not specified
