Phong and gouraud views don't work
                I am thinking this has got to be a bug in the program.  When I tried doing 3d views with the MTS to show a phong or gouraud view, my viewports don't show it correctly.  I am sure someone here has encountered this.
I show the polyline view, and the phong view of the same exact sheet that I print in the pictures.
Sam
Edited by user  Friday, October 7, 2022 2:20:53 PM(UTC)
 | Reason: Not specified
creativecad attached the following image(s):
(161kb) downloaded 2  time(s). You cannot  view/download attachments. Try to login or register.
    ViaCad 10 Pro
                I have sometimes also such half drawings with phong or gouraud, but this errors will be not printed and will  be fixed after zoom using. This problem i watched only on bigger projects with many parts.
    OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB |  Graphic: AMD Radeon RX Vega 56 | SharkCAD 15 Pro | Unit: mm
                for OpenGL problems under Windows do a driver update of the used graphics card ("Win+R > dxdiag") first. If using a lame integrated solution (e.g. intel (U)HD series), you might want switch to a dedicated nVidia GeForce GTX/RTX graphics card too, at least if a desktop system.
                It's not graphics. I reported this ages ago. The shading seems to be converted to an image. You see this when you load it in certain pdf software. When the image is removed you can see what's underneath it. The image blocks off what's next to it. Make sure view boarders do not overlap and you may get away with it
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
