la mouche
#1 Posted : Wednesday, June 24, 2009 4:50:01 AM(UTC)
la mouche
Hello,
a demo for my problem or limitation to SharkFX.
The object (diamond) [COLOR="Red"]twist[/COLOR] on the guide line.
It would be nice if Tim could implement a function of [COLOR="Red"]constraint guide to the normal of the surface[/COLOR]
http://rapidshare.com/files/248058135/Faberg_.swf.zip
for memory:
http://forum.punchcad.com/showthread.php?t=2321
clic and drag the .swf to your browser.
Please Tim? a suggestion, evolution?
Thanks and cordialy.
Antoine
zumer
#2 Posted : Friday, June 26, 2009 12:29:03 AM(UTC)
zumer
Antoine, your task is very specific for a general purpose design program. Can you use a mesh copy of your surface to define the surface normals, place one copy of your jewel at each latitude, then rotate/copy each about the axis, or rotate/copy all and delete those you don't require? I'm using VC3D, but Nick's movie about alignment with Shark makes me sure that the alignment tools in Shark would work fine with the facets of a mesh.
mesh for normals.jpg (52kb) downloaded 5 time(s).
la mouche
#3 Posted : Tuesday, June 30, 2009 3:34:02 AM(UTC)
la mouche
hello,
merci zumer.
I need a very precise positioning
but...
it's not just diamonds that need to be perpendicular to the face ...
should I show you examples of using this design?
here's a phone! :eek::eek:
here, a link that talks about the same subject
http://forum.punchcad.com/showthread.php?t=2418
Cordialy
Antoine
la mouche
#4 Posted : Tuesday, December 1, 2009 3:59:41 AM(UTC)
la mouche
Tim?
merci merci merci!!!:D
Hurray!
Finally, after long years of waiting ... SharkFX [COLOR="Red"]V7[/COLOR] is finally able to distribute items to normal surfaces.
http://www.screencast.com/t/M2IxOWQ0ZmE
I'm verry happy
good job Tim and team.
Antoine
#5 Posted : Wednesday, December 2, 2009 3:02:08 PM(UTC)
>>SharkFX is finally able to distribute items to normal surfaces.
Awesome, thanks for checking!
