la mouche
#1 Posted : Wednesday, June 24, 2009 3:19:58 AM(UTC)
la mouche
Hello,
It's possible reduce the tolerance for a correct or preserve geometry with the "join curve" tool?
Thanks.
Antoine
before join curve.jpg (29kb) downloaded 5 time(s).
after join curve.jpg (33kb) downloaded 5 time(s).
#2 Posted : Tuesday, June 30, 2009 1:08:43 AM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Originally Posted by: la mouche Go to Quoted Post
Hello,
Thanks.
Antoine
Hi Antoine,
I suspect one of your two curves is a spline. If you join two lines, you will get a polyline that preserves the discontinuity. If you join anything else, it will make single C2 continuous curve. When you have a sharp discontinuity as in your image, your going to get deviations at the join point as making the resulting curve C2 is the priority.
la mouche
#3 Posted : Tuesday, June 30, 2009 3:03:37 AM(UTC)
la mouche
thank you Tim,
I no longer have model, but I send you a sample as soon as possible.
