PowerPack
I need help with mesh to analytic tool please.
I started by removing all the collapsed facets. Then I use the mesh to Analytic tool which in return gives me an error message of "Unable to convert mesh element into analytics".
What else do I need to do to convert my mesh model into a solid, so it can be printed on a 3-D printer? Any information would be greatly appreciated.
(540kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 45 times Was thanked: 246 time(s) in 170 post(s)
I'd chuck it in meshlab or cloud compare sample it to generate a point cloud. Then remesh it. Export the mesh to your slicing software. The tool you are trying to use converts it to a solid acis model. I doubt it would work with something that complex
ViaCAD Pro 10, 11+ Power Pack Pro Shark CAD Pro V12 + Power Pack Pro Windows 10 Pro- MSI GL72 6QC-32GB RAM
Hi Ugmentalcase, Thank you for your help and recommendations! The "Point Cloud" is way too advanced for me. I did get to use it in Meshlab instead. Alex,
Point cloud to analytics finds planar, cylindrical, conical, ellipsoid surface sections in meshes. It's suitable for mechanical and csg-type models, it's completely irrelevant and inappropriate to your statue mesh. You don't need to convert it to a CAD solid at all to 3D print, and if you're using Cura as a slicer, it accepts six or seven import formats for your model and it's tolerant of notional flaws that will stop SLA or other UV-cured resin printers. If you want to modify your model, for example put it onto a base, PunchCAD V12 does much better mesh booleans than earlier versions, make the base as a mesh and it should add to your model as you'd expect solids to add. Failing that, Meshmixer, a freeware app that Autodesk took in-house for a while and added good features to, like mesh trimming, closing, shelling and booleans like this, will do it.
1 user thanked 2murray for this useful post.
PowerPack
