Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
Hello,
since i upgradet to Montery,
SharkCad 12 ( built 1563 )shows no entities and layers.
I could't find any information here in the forum.
So i downloaded the preview ( built 1591 ), this works.
Edited by user Thursday, February 3, 2022 4:40:50 AM(UTC)
a.wieneke attached the following image(s):
(288kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 1 times Was thanked: 8 time(s) in 5 post(s)
This happens since the very first builds, the concept explorer palette does not refresh. If you drag the concept explorer palette a litte by its size, it is refreshing and suddenly shows the entities. On one Mac with OS Mojave it happens all the time and make V12 useless. On one Mac with OS Big Sur ist does not happen. My V12 builds are 1582 on the Mojave Mac and 1575 on the Big Sur Mac. The check for current version never gives me any better result as 1582 on Mojave or a better result as 1575 on Big Sur. I never found a build 1591. That is crazy.
1 user thanked gebhardt for this useful post.
THANK you gebhardt,
your tip is working. But very crazy. in the dimension I have to click twice and now also in layers and entities.
So I have to learn, working around the bugs, instead of leaning key shortcuts. stupid.
the 1591 can you ask here in the forum :
#1 Posted : 3 months ago Retweet Thank Tim Olson Rank: Senior Member Joined: 2/2/2007 Posts: 5,065 United States Was thanked: 259 time(s) in 220 post(s) We have made significant progress in updating V12 to support macOS Monterey. If you would like to test the Work in Progress build, please visit the page below to download links for ViaCAD, SharkCAD and TurboCAD Mac. Download WIPhttp://www.masterviacad.com/beta/beta.php To report a bug please use this link:http://www.masterviacad.com/bugs/page5.php The links also include French and Italian installers and Build 1588 WIP for Windows. Thanks! Tim Olson
Thanks a lot, could load 1591 build a few minutes ago. Installed on both Macs, this works for me only on Big Sur OS, not on Mojave OS. Still not refreshing. Will update OS as soon as possible, but not Monterey. Regards, Lutz
mmmmh,,with the limited time version 1591, the palettes works fine on my computer with Monterey. so good luck :-)
