2D Drafting
Is it possible to add rulers along from origin, x & y axis
Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hello, I purchased this software to draw kitchen cabinet elevations. Some cabinet runs are over 12 feet wide. It would be much easier to layout the cabinets if there was a to scale ruler on the vertical and horizontal grid I have set up. Thank you, David H
1 user thanked dah59 for this useful post.
Thanks: 46 times Was thanked: 299 time(s) in 204 post(s)
You can make up a start file. So every new part started will load the scales. Draw out the scale you need in a file save as to desktop 'startup.dat' as the file name Move the file to C:\Program Files\Punch! Software\SharkCAD 12 (sharkcad 12 will show as whatever version you have installed) now start up the software and it'll load that default file. I have one set up full of renamed layers and things, just makes it easier
4 users thanked UGMENTALCASE for this useful post.
Thank you, I will give it a try. Hopefully this will make it possible to create drawings the same way as my old QuickCad software.
2D Drafting
