Solid Modeling
solid that's square on one end, circle on the other
Thanks: 6 times Was thanked: 5 time(s) in 3 post(s)
ViaCad Pro 11
How would I go about creating a solid that's basically a rectangle (or a cylinder, I guess) where one of the ends is square and one is a smaller circle? I need the surface of this solid to be smooth, so it has sharp corners on the square end, but tapers into a circle on the other.
I need to create this solid to subtract from the inside of another rectangular solid block. Basically it's the shape of the inside of a tube that starts at a square and ends at a circle. Does that make sense?
Edited by user Saturday, August 28, 2021 6:34:22 AM(UTC)
you can do this with skin solid or skin surface tools. see picture. with the "perpendicular skin" option you can otimize the shape
(120kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked rokoko for this useful post.
thanks. I've never used those so I'll have to dig into that a bit.
Oh wow. That was insanely easy to do. Thanks!
If it's for something like a duct transition to be bent up from sheet, using the ruled surface option will facilitate unrolling and shop production.
1 user thanked murray for this useful post.
The shape is similar, but this is for something 3D printed, inside a much larger outer block, which is why I need it to be a solid that I can subtract from another solid.
Solid Modeling
