                Hello,
Here is a problem that I have known for the Xenon.
Unable to do this, yet logical enough ...
See please the attach file.
This would be very useful for modeling watches.
Tim? Do you remember? I'm already asked, is there a evolution?
I watched your video for modeling the ring, but this goes with a circle base and is not valid with other tracks not based on the circle it seems.
Thank you in advance.
Best regards.
Antoine
(906kb) downloaded 5  time(s). la mouche attached the following image(s):
(51kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hello Antoine
Originally Posted by:  la mouche  I watched your video for modeling the ring, but this goes with a circle base and is not valid with other tracks not based on the circle it seems.
You can still follow the instructions from Tims video, it will work for oval shapes and many others.
I made a quick test.
pic 01: created the sections and path.
pic 02: copied the sections onto a straight line (of correct length)
pic 03: Bend the solid to the oval path.
It would be nice if we could have multiple sections allowed on a sweep path. It would save a lot of time.
(17kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                hello,
                Originally Posted by:  la mouche  Can you explain why the software does not want to do with guid skin solid please
I would say it is a bug. The guides are not being used.
You could try the "Guide skin surface" which does follow the guides.
                Hello,
I tried with the tool surface, but the error still exists.
Antoine
(36kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Antoine.
Originally Posted by:  la mouche  Hello,
Try adding more guides.
Tim,
Could you, when time, please look into this.
Regards,
- Steve
                Hi Antoine,
                Hello Antoine,
I was looking at the "skin solid" in VC. If I enable the "Perpendicular skin" (see pic) it does conform to a more acceptable shape.
Could you try this option in Shark to see if it helps.
- Regards,
- Steve
(40kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hello,
Here are the 2 files.
The problem is still there.
Thank you in advance for your solutions.
Antoine
 skin surf.sfx.zip
(323kb) downloaded 5  time(s). la mouche attached the following image(s):
(87kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
It looks like a bug that has been fixed in an update to be released.
http://forum.punchcad.com/showthread.php?t=1934 - Steve
                Hello,
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
