la mouche
#1 Posted : Tuesday, January 20, 2009 10:01:17 AM(UTC)
la mouche
Bonjour,
Selon les copies d'©cran ci-dessous, vous constaterez ces anomalies sous CU et SharkFX.
Soit:
1- construisez une surface plane.
2- d©coupez y un trou.
3-faites montrer points sur la surface.
4-essayez d'©diter des points de la surface afin de modifier son aspect.
5- constatez que le logiciel d©truit le travail pr©c©demment fait du trou sur la surface!!!
Un bug que je constate depuis la version Xenon...
Dans ce cas, tout travail surfacique est vou© l'©chec :(
Merci de faire suivre.
Cordialement.
Antoine
#2 Posted : Tuesday, January 20, 2009 12:55:27 PM(UTC)
Using Babelfish/Altavista/Yahoo, I'll try to help Antoine and the rest of us out:
"Hello,
According to the copies d' screen below, you will note these anomalies under CU and SharkFX.
That is to say:
1- build a plane surface.
2- cut out there a hole.
3-make show points on surface.
4-test d' to publish points of surface in order to modify its aspect.
5- note how the software destroyed the work previously made of the hole on surface!!!
A bug that I note since the Xenon version…
In this case, any surface work is dedicated to l' failure Thanks for making follow.
Cordially.
Antoine"
la mouche
#3 Posted : Wednesday, January 21, 2009 3:58:53 AM(UTC)
la mouche
Hello,
Here is another case where the work (draw points on z) on a surface destroyed.
Do you have a solution?
thank you in advance.
Antoine
Image 4.jpg (726kb) downloaded 5 time(s).
Image 3.jpg (29kb) downloaded 5 time(s).
Steve.M
#4 Posted : Wednesday, January 21, 2009 6:50:44 AM(UTC)
Steve.M
I can confirm this problem.
Example from VC (build 823)
I created a surface, projected/embedded the circle, then removed the cut section.(see attached pic+ model). Select the surface then show_points, then adjust one of the control points,.. the cutout is lost.
I exported the surface to check in another program. The surface imported correctly and could have the control points moved without the loss of the cutout, but I did notice that the exported surface did have overlapping CPs on the center section (I have ringed them in the pic)
cut.vc3 (22kb) downloaded 5 time(s).
la mouche
#5 Posted : Tuesday, February 3, 2009 3:19:04 AM(UTC)
la mouche
hello,
Answer is possible?
Thanks.
Antoine
unique
#6 Posted : Tuesday, February 3, 2009 4:20:51 AM(UTC)
unique
Hi Steve,
Somehow I would not expect this to work in a modeler of this kind. Tweaking "points" is something we do in Rhino or a surface modeler ;)
If you maintain the polysurface (with embedded curve) then modify the curve by editing points or direct input, then explode to surfaces..seems okay.
Just curious what format did you export ?
eg1.vc3 (39kb) downloaded 5 time(s).
la mouche
#7 Posted : Tuesday, February 3, 2009 4:59:03 AM(UTC)
la mouche
Hello,
ok thanks for your answer :)
Cordialy
Antoine
