2D Drafting
Nodes in viacad 2d version 9
Is it possible to reduce nodes/points to smooth curves for my plasma table in version 9.0.9?
What format are you exchanging? If it's .dxf, I think conversion to arc polyline might be available, but otherwise you might have to increase the resolution of the polyline equivalent. .dwg R14 has splines but I don't think VC gets curve output to sheet, upscale Shark mentions CATIA true curve licensing.
Edited by user Saturday, November 14, 2020 3:06:43 PM(UTC)
1 user thanked murray for this useful post.
It is .dxf I'll try to find more info about conversion to arc polyline and changing resolution. I'm new to viacad and not familiar with the majority of it. It's not like any cad system I've used before.
Thanks: 8 times Was thanked: 77 time(s) in 39 post(s)
There are tools for adding or subtracting points on a spline.
(671kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: FoxxFabrications Is it possible to reduce nodes/points to smooth curves for my plasma table in version 9.0.9?
Hello
I would recommend converting the multiline polylines to arcs before exporting. There is the tool in arc pallet to help "Arcs from Curves". Splines and multiline polylines do not cut well on CNC with all the stops and starts the arc tool will help. What is the geometry you are cutting?
Edited by user Tuesday, November 17, 2020 6:26:00 AM(UTC)
(45kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
2D Drafting
