la mouche
#1 Posted : Tuesday, March 17, 2009 4:19:40 AM(UTC)
la mouche
hello,
I see a bug on with grid. with SharkFX 5.0 (750)
Preferences do not maintain the settings of the grid to 10x10, from one session to the other ...
it is set to 10x10, and then convert to 9x9 :(
Cordialy
Antoine
ttrw
#2 Posted : Tuesday, March 17, 2009 4:26:10 AM(UTC)
ttrw
Have you tried upgrading your version of Shark to v5.5?
#3 Posted : Tuesday, March 17, 2009 4:48:20 AM(UTC)
not seeing that in 5.5 Antoine
however, the grid is still very inflexible
I can't believe there is still no way to ..
- draw a grid that is not centred around the origin .. but to positive x and y where most objects are created
- draw a grid to the extents of a given object
- draw an infinite grid
ttrw
#4 Posted : Tuesday, March 17, 2009 4:52:01 AM(UTC)
ttrw
Good points Jol :) I'll second those.
The grid should also be more transparent. Sometimes the grid can get in the way of the model view :mad:
#5 Posted : Tuesday, March 17, 2009 4:59:26 AM(UTC)
Hi TT .. glad someone agrees - I've only been nagging for TEN BLOODY YEARS now : )
Anyway .. looking forward to a tuned Grid in V6 Tim !!
With regard transparency .. you can set the grid colour to a lighter grey if you like - this will have the same effect
However, Tim - you need to effect this by default .. grid should be akin to the very feint lines you see on a gridded drawing pad
ttrw
#6 Posted : Tuesday, March 17, 2009 5:04:19 AM(UTC)
ttrw
Well no. I disagree! I've tried this, and it doesn't work! :eek:
Instead of staying a nice subtle silvery grey- it changes opacity depending on what angle the grid is viewed at. Sometimes again, this can be very obtrusive. But I too agree with your final point Jol, these grid lines should stay very faint all of the time, in the background. :)
#7 Posted : Tuesday, March 17, 2009 5:04:51 AM(UTC)
Another thing I SIMPLY CANNOT UNDERSTAND with regarding Grid
(Yes - after 10 years, you are entitled to shout !)
A new user (or someone trialling the software) opens a new window for the first time, turns on the GRID (which should be under view, NOT workplane) .. and what does he/she see ?
Nothing at all ! You can only assume it's jiggered
It's not till you zoom right in that you will find your grid .. perhaps it's different when setup is in inches .. but try - open a new window and turn on the grid .. you will see nothing
This is just pure UNINTUITIVE, BAD setup !
Hope I'm not here in 2019 saying the same thing ; )
ttrw
#8 Posted : Tuesday, March 17, 2009 5:08:41 AM(UTC)
ttrw
Yes. I stand by you on that one too Sergeant Major Jol! :D
#9 Posted : Tuesday, March 17, 2009 5:13:40 AM(UTC)
Here's Maxwell's grid .. sorry image isn't too clear - but it fades slightly to the outside of your view - giving the effect that it's infinite
Alias ST is similar
Let's get up-to-date with the Grid - I can't believe it's beyond us !
.. our grid is a left over from bygone days
#10 Posted : Tuesday, March 17, 2009 5:49:03 AM(UTC)
Antoine - sorry to hijack your thread and turn it all bitter and resentful ; )
ttrw
#11 Posted : Tuesday, March 17, 2009 5:55:44 AM(UTC)
ttrw
One thing very much in Tim's favour, is that unlike all these "good-grid" apps, we don't have to suffer that intolerable doom-grey background!! :eek: :D
