Hax||
#1 Posted : Friday, April 10, 2020 3:46:53 AM(UTC)
Hax||
Ok, I'll do my best to explain this.
I want to make a curved duct that is ellipse in shape and larger on one end that curves to a spline.
I've been able to get it to go straight as a solid (not a big deal, can work with a solid result). If I try just a round pipe, it turns at a right angle.
Tried 1 & 2 rail sweeps. I get an unknown error on 2 rail sweeps (I select the 2 ellipses then the spline to follow.)
Shark Pro 11 on a Mac.
Edited by user Friday, April 10, 2020 10:13:39 AM(UTC)  | Reason: typo
L. Banasky
#2 Posted : Friday, April 10, 2020 9:11:16 AM(UTC)
L. Banasky
Might be able to help if you can post your file.
Have you tried 'Lofting'?
Hax||
#3 Posted : Friday, April 10, 2020 9:59:28 AM(UTC)
Hax||
Thanks, Will pour into lofting.
But here is a cut to basic, i'm trying to do.
Duct-Test.sfx (6kb) downloaded 7 time(s).
horst.w
#4 Posted : Friday, April 10, 2020 3:07:23 PM(UTC)
horst.w
I have the same trouble with sweeping up a closed curve with 2 rails. With only 1 rail it is running.
The rails are curves to bend the part in two directions (z and x or y )
For the moment I could solve the problem if I bend the result of sweeping 1 curve with Center-Bend-function.
I'm sure, it was running in olden days.
horst.w
GER
horst.w
#5 Posted : Friday, April 10, 2020 3:23:04 PM(UTC)
horst.w
Only an example ,
curve like " L " and 2 rails
Version V 10
is running well.
H.
Sweep 2 Rail V10.jpg (74kb) downloaded 2 time(s).
mitchb
#6 Posted : Friday, April 10, 2020 10:40:37 PM(UTC)
mitchb
Was thanked: 75 time(s) in 38 post(s)
Try a "Centerline Skin", had to force the oval axis to tangency with the curve.
Screen Shot 2020-04-10 at 9.37.18 AM.png (509kb) downloaded 15 time(s).
thanks 1 user thanked mitchb for this useful post.
Hax|| on 4/11/2020(UTC)
Hax||
#7 Posted : Saturday, April 11, 2020 6:29:43 AM(UTC)
Hax||
Hey! That seems to work. THANKS!
