Thanks: 14 times Was thanked: 3 time(s) in 3 post(s)
Hello,
Coversurface is not working in ViaCad 11 pro.
When i export this file to ViaCad 10 pro,
Coversurface is working.
Wondering
see attach
not cover.vcp
(21kb) downloaded 5 time(s). a.wieneke attached the following image(s):
(329kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 1 times Was thanked: 9 time(s) in 5 post(s)
Thanks: 46 times Was thanked: 285 time(s) in 192 post(s)
Got it pretty good by changing the surfaces to curves. Taking a load of points along the curve then using lines and skin surface.
Odd the surface fill isn't working. Should do that I would've thought
not cover.vcp
(42kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
ViaCAD Pro 10, 11+ Power Pack Pro Shark CAD Pro V12 + Power Pack Pro Windows 10 Pro- MSI GL72 6QC-32GB RAM
Originally Posted by: UGMENTALCASE Got it pretty good by changing the surfaces to curves. Taking a load of points along the curve then using lines and skin surface. Odd the surface fill isn't working. Should do that I would've thought
Thank you, i understand.
My idea was, why can do it ViaCad 10 with one klick
and ViaCad 11 needs a work around
Edited by user Saturday, March 21, 2020 6:21:59 AM(UTC)
Yeah Version 11 is an odd one. Has many problems that don't seem to be getting resolved.
