carsten
#1 Posted : Thursday, January 16, 2020 11:28:47 AM(UTC)
carsten
Was thanked: 10 time(s) in 10 post(s)
Hello, everybody,
i have a short question that confronts me with a big problem. i am currently using Shark Cad 10 with Power Pack Pro 10. for a steel work i am drawing an entrance gate in 2D. Here I have to determine a cutting list / part list for the lengths of single bars. So I only need simple lines in the drawing from which I need the length per object calculated and then output in a BOM. Now I found out that this works well with the cut list as long as the objects are drawn in fixed 90/180/270 degree angles to the coordinate system. But as soon as I draw a line for example in 45 degrees or another angle these lengths are no longer correct. It is even worse with curved lines here I get no lengths of the parts at all.
My question is whether there is any way to create a parts list that gives me the length of single lines and composite lines?
Is there anyone here who can help me with this problem? Thanks a lot in advance! Sunny greetings
Carsten
Edited by user Saturday, January 18, 2020 2:06:05 AM(UTC)  | Reason: Not specified
carsten attached the following image(s):
#2 Posted : Tuesday, January 21, 2020 5:18:52 AM(UTC)
you can add dimensions or you can verify length and writing the values per hand in the cut list. But Punch CAD will not do this automatically in a cutlist in the right way. Also not when you use the new tool for defining the lenght direction.
Edited by user Tuesday, January 21, 2020 5:23:29 AM(UTC)  | Reason: Not specified
carsten on 1/27/2020(UTC)
carsten
#3 Posted : Monday, January 27, 2020 9:30:22 AM(UTC)
carsten
Thanks @MPSchmied! Looks like i have a lot of trouble with that CAD system as all the things i wanted to do with it alway lead me into a oneway road. Messuraing everything from hand does not make so much sense as this drawing ist far more complex than the part that is shown here. But i checked a little bit around and got a way to use the perimeter BOM value to get the length i needed. But it was not realy intuitive :-)
See we both are from germany - so nice to know that i'm not the only person using Sharkcad here in the country.
greets
carsten
