gebhardt
#1 Posted : Thursday, January 16, 2020 4:06:13 AM(UTC)
gebhardt
Was thanked: 10 time(s) in 6 post(s)
In adding fillets and chamfers is is very useful to have a part in transparency view shading.
Can we have a function to toggle quickly between transparency and non-transparency?
Or is it available anyhow? Have not found it yet.
Best regards , Lutz
#2 Posted : Thursday, January 16, 2020 4:51:43 AM(UTC)
Was thanked: 180 time(s) in 108 post(s)
Best regards , Lutz
Hello Lutz,
Object property---> Display---> Transparency
Capture d’écran 2020-01-16 à 11.46.06.png (449kb) downloaded 0 time(s).
gebhardt
#3 Posted : Thursday, January 16, 2020 7:05:08 AM(UTC)
gebhardt
Yes, this is what we use permanently.
But this does not work quick enough for me.
I use
Pick Objekt > right click > transparency
or
Pick Object > Inspector > Display > Apply
I have now set a shortcut to toggle very quick between gouraud shading and wire frame shading.
Works now for me, but applies to all objects, which ist a bit confusing while have a lot of detailed parts in wire frame.
creativecad
#4 Posted : Thursday, January 16, 2020 11:31:39 AM(UTC)
creativecad
There is a couple of options at the bottom of the main tool pallet to change to wireframe or dimmed hidden lines.
ViaCad 10 Pro
ViaCad 9
Windows 10
#5 Posted : Thursday, January 16, 2020 2:03:40 PM(UTC)
Can you bang it on a keyboard shortcut? I have a few set up with my space mouse. It has a few buttons on it which I have programmed (shortcuts) to regularly used things
creativecad
#6 Posted : Thursday, January 16, 2020 8:05:42 PM(UTC)
creativecad
I thought I posted a response but it disappeared. Anyway, yes you can go to the Render commands in the Shortcuts. There are options there to assign a key to toggle between wireframe and a shading type.
ViaCad 10 Pro
ViaCad 9
Windows 10
gebhardt
#7 Posted : Friday, January 17, 2020 6:09:29 AM(UTC)
gebhardt
I have set a lot of short cuts to f.e. show hide functions and various standard views. This makes me very fast in view manipulation.
Now i have set an additional short cut to toggle quickly between my standard render mode "Gouraud with edges" and "wireframe".
What i would love ist to have a quicker possibility to add or remove transparency on a specific parts.
Nice to have...
