Inspector:Default Settings Box
Thanks: 156 times Was thanked: 150 time(s) in 103 post(s)
SharkCAD Pro 10 PC, any way to make the box larger?
I need to select one of the Times New Roman fonts
out of the six available.
(46kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 46 times Was thanked: 319 time(s) in 212 post(s)
I bet there's a size for that in the. ini files somewhere. There's one called dialog.... Something maybe try that one first?
Thanks UG,
Searched the .ini and dialog files, and didn't really
find anything that I could edit.
Maybe I should post in suggestions, with examples of
other software handling of long named fonts.
Thanks again,
(37kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Yeah turning on selectfontdialog shows a little bit more but not a lot. They need to make it resizeable like the concept explorer, and then you can edit the .ini file to a preferred size.
(26kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
