Dickon Whitehead
#1 Posted : Saturday, June 8, 2019 6:54:06 AM(UTC)
Dickon Whitehead
I would like to see construction lines show on top of filled objects, is that possible using the default construction line in the construction layer?
Attempting to get that result with Bring To Front command causes the construction line to become invisible, Undo does not make it visible again. Line still exists in the Concept Explorer
Guest (5)
