la mouche
#1 Posted : Wednesday, January 19, 2011 9:17:55 AM(UTC)
la mouche
Hello,
Solid extrusion tool can not be extruded non-planar curves.
But ... know that you can extrude non-planar surfaces? ----> with the solid extrusion tool.
yes yes :eek:
example:http://screencast.com/t/vO7F60ohn
Antoine
misterrogers
#2 Posted : Wednesday, January 19, 2011 11:44:35 AM(UTC)
misterrogers
Nice. No more error messages about being non-planar..
Jean-Francois Jacques
#3 Posted : Wednesday, January 19, 2011 3:58:15 PM(UTC)
Canada
Good Antoine.
But I not understand the logic!! If it's possible with a surface...and for the surface you need a close path of lines, why we cannot extrude with the lines. Tim you must write some more code lines!!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
Tem
#4 Posted : Thursday, January 20, 2011 11:24:42 AM(UTC)
Tem
Possibly, it is an issue with curves, not lines?
I don't have time to test right now, maybe this weekend...
