Solid Modeling
DeformFace-Menue vers Pattern
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
it has occured an issue in the MODIFY > Solid-Direct-Edit menue.
As you can see on the hardcopies of the screen, the menue contains 9 points, the last one is DEFORM FACE and there is no point "Pattern".
While I have worked and would use the Deform Face Option via my tool bar, the DeformFace flashed shortly on and after this it was changed to an unknown menue point "Pattern".
In the tool bar the last point is now Pattern and Deform Face has disappeared. Even if I select in the MODIFY-Menue the Deform Face option, it is linked to Pattern and I can not reache the Deform Face option.
Very strange!
Does somebody know how to turn it back or how to complete the menue options list? The Pattern-option may be very helpful but I need the Deform Face option instandly!
Best regards
horst.w
GER
Edited by user Sunday, January 20, 2019 3:31:24 PM(UTC)
(318kb) downloaded 17 time(s). You cannot view/download attachments. Try to login or register.
Yeah I reported this and Todd repeated his end.
Thanks, I hope to a fast solution! H.
Thanks: 550 times Was thanked: 45 time(s) in 33 post(s)
What ever happened to the deform face tool? I never have seen that feature on my copy of ViaCad pro v12 powerpacked. I have seen that tool in the documentation. And read horst.w post about the missing deform tool. Does it even exist? Or did it just dissappear like the mesh to nurbs feature.
Solid Modeling
