Solid Modeling
Finding A Non Planar Complex Parting Line
Thanks: 3 times Was thanked: 4 time(s) in 4 post(s)
US VC9 2d/3d Pro 64 is there a way to find a complex non planar parting line for making a mold.
Originally Posted by: Bob La Londe US VC9 2d/3d Pro 64 is there a way to find a complex non planar parting line for making a mold.
It appears that this is not a feature in ViaCad and there does not appear to be a brute force method either. I had thought of, (but not tested) a brute force method using CamBam with STL models. I described my idea (but not yet tested) on the CamBam forum where the user EddyCurrent appears to have modified parts of other plugins to create a plugin to automatically create a non-planar silhouette that might serve as a very substantial starting point for what I hoped to achieve. For those interested in a possible solution to a similar problem you can read about it here:
http://www.cambam.co.uk/...m/index.php?topic=7799.0 on the CamBam forums. Please don't be afraid to ask question on the CB forum. The other users are among the most helpful I have found anywhere on any forum.
Was thanked: 41 time(s) in 21 post(s)
I guess "Silhouette Curve" might do the trick. I'm not shure though, if it's available in Viacad 9.
Originally Posted by: cad' I guess "Silhouette Curve" might do the trick. I'm not shure though, if it's available in Viacad 9.
Depending on how it works that might interest me in upgrading. Do you know of a demo video of that tool/feature? Do you know what versions it might be available in?
here the description in the manual of viacad pro 10:
(157kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: cad' .... if it's available in Viacad 9.
Yes, it is!
horst.w
GER
Edited by user Sunday, January 13, 2019 3:38:33 AM(UTC)
(45kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked horst.w for this useful post.
Interesting. My first test does produce a result. I created a 3D pipe from a 3D spline and produced a silhouette in 3D. I'm not yet certain if its a useful result, but its certainly a step in the right direction.
Thanks: 46 times Was thanked: 308 time(s) in 207 post(s)
Is this something you want to do in a 2d plane like the image above, or be able to do it 3d? As you could copy the face and move it backwards to be central and then use plane cut, or similar to divide the part using the surface?
Rail sweeping the faces of the part along two orthogonal rails and intersecting the sweep parts will extract the partition, I think. For solid obects, anyway, I don't think meshes will be cooperative with that.
Solid Modeling
